SERVICE LUZ IN RENAULT 21 TXE
16 years 2 months before #9208 by manual-mecanica
Luz Service in Renault 21 Txe published by Manual-Mecanica
Good to all .....
I have a problem with my R21 txe injection ...
I flash the Service light in the painting, along with the electrical signal drawing ...
could anyone tell me what can you give this ???
Is it related to injection ??? Or can it be for something else ???
It is not fixed, simply flashes from time to time ...
in advance ... thank you very much ..
16 years 2 months before #9226 by manual-mecanica
Manual-Mecanica Answer on the Re: Luz Service in Renault 21 Txe
Aver here in Chile the Servis light refers to the light indicating oil change or distribution strap change and that, the Chekengine light is the warning of the electronic injection system, it depends on which one you mean, if you have the drawing of an engine or says check, it is the injection, if it is not the other. If it turns on, it is only a current problem for one thing although in some extraordinary cases it is turned on by a land problem. Now it is important to check it since it tells you of a problem and the computer is in a state of emergency, if you do not notice a change in the walk you do not let yourself be and try to scan it, it is the best way of saver, and the long one the most economical since you do not change things to the hazar, someone will tell you that it is flowing another tps and thus, now it has some real problem your car or is it only the light?
15 years 10 months before #10777 by manual-mecanica
Thank you companion, I think everything is a fault of a bad contact in the injection input air sensor, I checked it, and it has not come again ....
Thank you very much
