Problems with the starting engine, Aguien knows
16 years 2 months before #9122 by manual-mecanica
Hello, the other day, the starting engine was stuck, it always happens that it does not start, in most of the breakdowns. But it happened to me that it was hooked to the engine, I left the smell of burning and tube that urgently disconnect the battery, then there was no way to stop it. It is not before. My question is whether you know any procedure to try to recover it.
Thanks in advance.
16 years 2 months before #9123 by manual-mecanica
Hello partner, so you comment, you are stuck the ssolenoid that the Bendix commands, you are very likely to have to change the induced and you have to review the fields for burns or short luck.
