Pare Valve Ibiza TD year 96
16 years 2 months before #9113 by manual-mecanica
Pare Valve Ibiza TD year 96 published by Manual-Mecanica
Hello, it is the first time I write in a forum. Seeing if you can help me I need to locate the vavula of an Ibiza of the year 96 Turbo Diesel. If you told me where you are or where I can download a pump manual I would appreciate it.
16 years 2 months before #9115 by manual-mecanica
Manual-Mecanica Response on the Re: Pare Seat Ibiza Valvula TD Year 96
Hello friend, the stop valve will be seen in the back of the injection pump, it has a connection cable that brings you current for its operation you cannot be wrong, luck and greetings.
