Water filtration inside the car
16 years 2 weeks before #9029 by manual-mecanica
Water filtration inside the car published by Manual-Mecanica
Hello, I have a Peugeot 206xr 2007 and it is filtering water towards the driver's floor, the filtration comes from the pipe that carries water to the heating radiator, I stop that carries a kind of oring between this pipe. My consuilt is:
it can be changed without taking out the radiator
you have to disassemble Akgo on the board to make this change
who can indicate the steps to follow
in advance thank you very much
Edgardo
Chile
16 years 1 week before #9031 by manual-mecanica
Manual-Mecanica response on the Re: Water filtration inside the car
Hello Edgardo, you should have punctured the heater radiator and you will have to change it because it is plastic and normally it has no repair, the disarmament is somewhat complicated because you have to disassemble the console and part of the board, I advise you to take it to a house specialized in the subject and provisionally you can make a bipass joining both hoses with a tube of the right measure and 2 And do not download refrigerant in the room, luck and a hug.
16 years 1 week before #9037 by manual-mecanica
Jal is correct, you have to do what the Bipazz says is the best solution at this time it is fast and you can do it yourself, little you have to bleed the water system well if you are left to you the electros do not leave and the car is irregular, greetings, from which part of Chile you are, I am from Coquimbo if you are from here I can help, the bipazz is done in front of the vehicle.
16 years 1 week before #9040 by manual-mecanica
Hi, I'm from Talcahuano, I already solve it, seal the filtration of the pipe, and now all right thanks
15 years 1 month before #14673 by manual-mecanica
Hello my name is Walter, Gego a Fiat 147 Mod 95 and I have a water filtration enn the union of the parante and the fender, could someone recommend that I can solve the problem ... Thank you very much
