Problems with my Ford Focus
15 years 8 months before #11813 by manual-mecanica
Manual-Mecanica Answer on the Re: Problems with my Ford Focus
What goes off may be because it runs out of air compression, it is provided by a hose that is connected by motor behind, possibly if you have this failure you would also hear a kind of zizeo in the engine as if it swallows air and the brakes also the feelings also rare on occasion. Checalla! Possibly this only bad.
15 years 8 months before - 15 years 8 months before #11839 by manual-mecanica
Hello friend:
look ami also the same thing, only that I have a 2.0 spi engine, check or do what our friend Walterg tells you to point four, I would add a review of the pressure of the fuel line to see if it is fine before your jalones, and when it starts to pull if the pressure goes down until the engine is turned off, now if you lift the back seat you will see that you will bring a black box, this box is. The fuel pump, check that it is working well, that I believe that if if you did not start, or then it would be extinguished later, and finally it can be your fuel pump that is already covered by dirt or that its useful life has already ended, you will have to check if there is access by above, lift the rear seat or plane lower the tank to take it out, I pass it and turn it away and it turned it out and it would come out and it turned it away and it turned it away and it would come out and as if it turned it away and Until I was pulling and lost acceleration, until it went out, and so on and again.
From your velocimetro, I would not know how to tell you first instance, I would need to know if it is automatic box or standard, and if you have speed control.
I hope this
health
Latest edition: 15 years 8 months before by .
