Airbag Fiat Idea
16 years 3 months before #8833 by manual-mecanica
Airbag Fiat Idea published by Manual-Mecanica
Hello everyone, the idea I wanted to know if Algien has an airbag manual with sensor test and meaning of the failures.
The idea is the year 2005 1.8cc engine.
First of all thank you very much
16 years 3 months before #8837 by manual-mecanica
Manual-Mecanica Answer on the Re: Airbag Fiat Idea
Hi Cries, which happens to your Airbeg, the system of this element is complicated and half dangerous to manipulate when testing sensors of this component you run the risk of activating them by accident and it is very expensive to buy them is better that you tell us what problem you have and we try to help you, the best way to check this element is with diagnosis anyway, but you want to help you.
16 years 3 months before #8838 by manual-mecanica
Hi Kikemec, I tell you that I already scan and gave me several codes, the problem is that I have no explanation of the codes of how to try the sensors or electrical plane.
The codes are:
1 switchboard (fugitive)
26 Airbag Airbag Witness (permanent)
3 Connection between Averia and Ecu (permanent)
8 Explosive Load Airbag Conductor (permanent)
Atte. Cristian
16 years 3 months before #8842 by manual-mecanica
Look when he speaks of Fujitive, it is a current that is lost somewhere or of a permanent signal activation of any of the components, which refer to permanent are signs that are always found, you want to only be a land problem of the bee. Help you better.
16 years 3 months before #8843 by manual-mecanica
Hello, how do you check the plugs that are under the seats that the cables tend to break and do not make contact or the plug in humidity or dirt
