Wet spark plugs
16 years 3 months before #8808 by manual-mecanica
Wet spark plugs published by Manual-Mecanica
Estimated:
I have a problem.
I have an Opel Kadett year 92, everything is super good, until a change of the taquis was made, after this I turned on the vehicle, then when I stopped for some reason (example: I released the drunkenness in First) when I wanted to make it leave again I did not turn on, they told me that it was the problem of the spark plugs, that they get wet, why I do not know.
Please if someone can help me with this !!!!
Orientation.
Thank you
16 years 3 months before #8812 by manual-mecanica
Manual-Mecanica response on the Re: wet spark plugs
As first place, I recommend placing the right and not two -pointed spark plugs or four -pointed, only those that correspond if it improves, is your vehicle carbaded or injected?
