Ford Ka
16 years 5 months before #8779 by manual-mecanica
Ford Ka published by Manual-Mecanica
Hello, could anyone help me ??? I need to remove the cover of the carter from a Ford Ka 2007 pro I can not see it for the first time you already remove all the screws that are in sight but does not come out someone can tell me how to remove it ????
16 years 5 months before #8780 by manual-mecanica
Manual-Mecanica Answer on the Re: Ford Ka
If you are already sure to have removed all the carter screws, the problem is that the factory silicon is difficult to take off, you can do it with a flat screwdriver supporting one of the corners, it gets a little hard when taking off, once the carter is taken off the carter be careful with the oil strain, you usually should incline the carter so that he can leave without hurting the strange.
16 years 5 months before #8782 by manual-mecanica
Friend the carter does not release you and will not release you because you need to remove two bolts, if your model is k as well as the one I think that year 2000, the problem is as follows, it has two bolts that are hidden you will have to take out the gearbox and they are going in a urio -in -way inwards
16 years 5 months before #8788 by manual-mecanica
The same thing happened to me with a 2002 Ford Couer to remove the speed box to remove the carter lid.
16 years 5 months before #8790 by manual-mecanica
Hi Blackboy for your bad luck Kikemec and Gaudencio05 are all right with their observations. But look at the good: take advantage of Chear /Change Rel Clutch and the retain of the cgüiëñal a time you have taken the box of the changes. Safe.
