Petroleum filter
16 years 1 month before #8705 by manual-mecanica
Oil filter published by Manual-Mecanica
Messrs. Recently changes air, oil and oil filter and several times the jeep (Isuzu Bighorn) the engine stops, could inform me that it can be, because the mechanic tells me that it can be air
thanks
16 years 1 month before #8706 by manual-mecanica
Manual-Mecanica Response on the Re: Petroleum Filter
If in addition to stopping and pulling, it could be a air problem, but it is not very normal for air to get into the oil feed system because of the oil filter, did you put the chargodo filter, right?
16 years 1 month before #8709 by manual-mecanica
The filter is the original and was loaded, but it does not mark only stops, if I immediately start a problem, both hot and cold, in yesterday it was purged to rule out the air in the filter but after about 10 blocks it happened again, they tell me that it can be a sensor.
16 years 1 month before #8718 by manual-mecanica
If it were a sensor, the Chack's light teaching at some point, it may be that you have a problem with the oil pump, or want some kind of water or dirt in the feeding system,
16 years 1 month before #8721 by manual-mecanica
You might leave some hose without connecting the air filter or some connector, check them and let me know
