Hello, I have a problem with Chevrolet Combo Diesel
16 years 3 months before #8672 by manual-mecanica
Hello, the problem I have is that I lose strength in the climbs with the truck
It was made completely tune to the engine and it is the same, the only thing that does not do it is the check of the injection pump because I do not know how they are registered, neither does I know how much is the compression they have
This type of engines, any there I will be grateful for them
chau ... :)
16 years 3 months before #8676 by manual-mecanica
I think you have a Camon Rail injection, the most caused thing is that you have the bad lift valve, but it is best to send the bomb to check is my opinion, the other is that the past allas in revolutions if so you will have to put it on the computer to repair it.
