The long lights are not turned on in the R21
19 years old 2 weeks ago #858 by manual-mecanica
The long lights are not lit in the R21 published by Manual-Mecanica
Hello,
my problem is that it does not change from short to lengths, however it allows me to give raffles (only in position lights or with the lights off), the question is whether the change from short to lengths is done by the lever of the lights itself or passes through some auxiliary relay.
Greetings and thanks
18 years 11 months before #979 by manual-mecanica
Manual-Mecanica Response on the Re: The long lights are not turned on in the R21
In the 21 it goes straight from the command, and you have the command of bad lights, solution, go to scrapping and take one.
