Motor Reset Oil BMW 320 D
16 years 4 months before #8605 by manual-mecanica
MANUAL-MECHANICS APPLICATION ON THE REPEEO MOTOR CHANGE OIL BMW 320 D
I will try to look for it and I will tell you, I have the BMW tis is the repair and data program like those used by the consciousness but they are on DVD and I would not know how to pass it to you, or if you can but any information you need to share it.
Greetings we continue in contact.
16 years 4 months before #8611 by manual-mecanica
Thanks José Ángel in advance for everything, and if I can help you something, do not hesitate to communicate it, although I don't know what I can do.
Sincerely FCO Port.-
14 years 1 month before #25662 by manual-mecanica
Hello left. I don't know if you'll be there, after two years ...
The fact is that I have a December 320, 94 and it doesn't work for me.
I get to see this:
Reset
Oil Sia Sia
Pulse The button you say and I appears
reset (a clock in a square)
8.08 sia
holding pressed ... flashes ... I release
pulse ...
End sia
everything disappears ... but nothing happens, the oil service is not removed
I would love that you could give me the manual. I have a web space, if you want I give you a FTP and you upload it to me.
14 years 1 month before #25664 by manual-mecanica
Hello, if I am here after more than twenty-five years of German Automobiles, especially, returning to your case, I do not know any diesel engine in that year 320D, it is those years. The body E-36, E-34, E-38-E-31 Find out and answer you, a greeting from Tenerife
14 years 1 month before #25674 by manual-mecanica
Hello left
I send you the 7 numbers that you tell me and some more data in case it can be useful:
(what it says to the technical file)
The last 7 numbers: KV74526
enrolled on December 23, 2004
Type Motor: 20-4D-4 D
Commercial denomination: Series 320d M.
Thank you for your interest
Greetings from Asturias
Javier
