ATF level Daewoo cloud gearbox
16 years 4 months before #8456 by manual-mecanica
ATF level Daewoo cloud gearbox published by manual-mecanica
Estimated, my query is if anyone knows how to measure the oil level from the Automatic Change Box of the Daewoo Nubira 2.0, I have doubts with the level since I had a small loss that solves it, I will appreciate if someone can answer me, greetings
16 years 4 months before #8462 by manual-mecanica
Manual-Mecanica Response on the Re: ATF level Daewoo Nubira gearbox
Hello friend, look, I do not in your special model here are not very common, automatic or 2.0 engines, well if there is no rod that would be under the hood, the most caused schens have two plugs in the box itself, one is drain Mazda Artis has this system that I tell you.
16 years 4 months before #8466 by manual-mecanica
Dear, thanks for your response I will check the box if I find the plugs you mention hopefully this is the way to check the level, I barely make them inform
12 years 2 months before #43064 by manual-mecanica
Manual-Mecanica response on the topic of ATF gearbox daewoo cloud
Hello in the upper part of the automatic box, there is a red lid below the battery with a despiche hose ... in it says Fill Full ... which means filling completely ... I understand that the ATF is filled here until the maximum ... greetings
12 years 2 months before #43089 by manual-mecanica
I have been looking for and that box has 2.5 l of capacity so if you want to close that the box has the right level you can empty it and fill it with 2.5 L. If you want to take advantage of the lubricant you can pour it on a clean cauldron so as not to peder it
