98 goal gasoline pump problems
16 years 4 months before #8266 by manual-mecanica
Manual-Mecanica response on the Re: problems with Gol 98 gasoline pump
The first thing you can do is checar, the current reaches the pump connects a multimeter and if the current low when your fault wants to say that it is the relay or the fuse and if the current correctly arrives s your pump that is about to burn and the way of economizing is buying the spare of the pump greetings
