98 goal gasoline pump problems
16 years 5 months before #8035 by manual-mecanica
98 goal pump problems published by Manual-Mecanica
I'm looking for the 98 goal mechanic manual since I have several breakdowns and I would like to solve it. One of them is that the gasolila electric pump is failing me and I don't know if it is reeley, fuse or if it is a pump, sometimes you send gasoline and sometimes not? It is crazy and I want to be sure that it is the bomb so as not to make unnecessary expenses. Please you can help me. This is my email . Tarete to download it because of qaqui but I could not if someone already has it can be sent to my Carreo. I thank you.
16 years 5 months before #8039 by manual-mecanica
Manual-Mecanica response on the Re: problems with Gol 98 gasoline pump
As advice I would tell you to try the pump outside making it work to see if the shipment cuts, if it is for economy, it changes relay that can be stuck and the fuse, they are economical and discards immediately.
16 years 5 months before #8048 by manual-mecanica
Hello friend I advise you that as the first measure you change the relay to test it is not expensive if the problem remains disassembles the pump and the tests outside the vehicle so you will see if the supply is cut or if it pulls normally also checks the fuel filter in case it was partially covered, luck and communicate any novelty.
16 years 4 months before #8255 by manual-mecanica
I do not agree with my colleagues, as it is known to determine whether an electro-bomb does not work properly, several tests are done without taking it out of its accommodation, first fuel pressure, second fuel flow, if this is right or badly determined what is the power cause? BUT .
I hope the report serves and may my fellow take it badly.
According to your indications sometimes it sends fuel and sometimes not, verify at that time if the voltage of the electro-bomb varies.
greetings.
16 years 4 months before #8261 by manual-mecanica
Hello, I had a similar case in my 95 goal, they are the same system as that of 98, the car never turned off but if it significantly lost the power, a typical prophylema in the electrical system of the gasoline pump, the pump relay usually has cold wages (cracked or loose salary points). I advise you to take the bomb relay that is under the board in the driver's stall and check it, if there are problems with wages you can solve it with a cautin and tin, if there are no news in the relay then you reburate the connection harnes and if so it still gives you problems you must perform the road tests with a pressure gauge to determine if there is a perecia change it.
