crankshaft draft point in Peugeot 306HDI
16 years 7 months before #7990 by manual-mecanica
crankshaft draft in Peugeot 306HDI published by Manual-Mecanica
Someone could tell me where is the crankshaft draft point in Peugeot 306 1900hdi.
16 years 7 months before #8000 by manual-mecanica
Manual-Mecanica Response on the Re: Crankshaft Drain Point in Peugeot 306HDI
If it does not bring the pulley, the most caused thing is that it is on the pineapple of the crankshaft, if you do not find it withdraws a spark plug or an injector if it is a petroleum, put a screwdriver and turn the engine by hand until you find the upper dead point, it recounts that the Peugeot piston 1 is the one on the box not of distribution, the French are the reverse of the normal ones.
16 years 6 months before #8016 by manual-mecanica
So you mean that the upper dead point of the first piston coincides with the camshaft draft and the injection pump, right?
16 years 6 months before #8020 by manual-mecanica
Aver the upper dead point is when the piston is just in the explosion phase, depending on your ignition order it can be the 1 or four, the injection pump brings marks and depending on your pump, they may all injected together or sequentially the pump must be as a tooth before performing the injection, when the engine is translated eventually in some of its points the marks will cross the marks. The pump in the PMS will be injecting but you must find out if it injects into one or 4 that determines and looking at, if you have everything disarmed, look that the brands exist, there are peugeotes who have the mark in the inertia steering wheel and can be locked with a screwdriver or llava Allen have a hole where he gets looking for this before doing anything
15 years 10 months before #11498 by manual-mecanica
The draft of the crankshaft is performed by a hole located behind the starter engine
