connecting rod problems
16 years 7 months before #7694 by manual-mecanica
connecting rod problems published by Manual-Mecanica
]How are you. As they are to see who can help me with my problem, look that my car had a problem with the rod tiles towards a sound and changed the tiles but the problem still follows it less but it is still heard uncover the carter and I realized that the connecting rod has a side game and is more than that of the others. What can I do
16 years 7 months before #7695 by manual-mecanica
Manual-Mecanica Response on the Re: connecting rod problems
That it is most likely that it does not have axials are special metals that avoid the lateral displacement of the cygiueñal.
16 years 7 months before #7702 by manual-mecanica
The game is done by the connecting rod the crankshaft it will be that I must change the connects
16 years 7 months before #7706 by manual-mecanica
I believe and support the one that the partner says, the axial metals avoid the dmployment also of the piston, because the connecting rod falls in a specific place, tell me a thing that of the pistons is the one that has a game, the two or the three, and tell me that vehicle you have a model and year brand. The displacement can be caused by metals in poor condition, or poorly installed or by modifying the bought that do not belong.
16 years 7 months before #7721 by manual-mecanica
If the connecting rod foot has an excessive game with respect to the crankshaft doll of the crankshaft. Maximum 0.4 If it is in the maximum it changes the connecting rod, measure again if you still exceed you must change the crankshaft too
