Turbo adaptation
16 years 4 months before #8025 by manual-mecanica
Manual-Mecanica Response on the Re: Turbo Adaptation
Look in the motors modification, it is said that any engine serves while you have space to put it, but if the MR2 is not common, it tries to get one of celica or for a walk those mottoos are mounted in front and not behind like that of MR2, usually the motor purchases and box all together, if you do not find them very fast, you can fix the cylinder head so that they run a lot, that is simpler than the turvo. Veils can be done, but remember that you also have to stop it and on occasions you have to make some small arrangements to the brake system, they are not Mchos, well look for engines tell us which one you want or which one you got and we will there to take a good discourse, abrases and take care.
16 years 4 months before #8030 by manual-mecanica
The true thought of modifying the exhaust miltiple and changing your exhaust Bo for a 2 -inch, also changing the standard pistons for competition, (I don't think it is sifcient) I also decided to change the rear brakes that are drum for dr disc.
16 years 4 months before #8038 by manual-mecanica
Watch the engines are enhanced more than block, you can revive the cylinder head, cruster, combine valves and valve bent pistons, shorten career, but it is better to do only the cylinder head to start.
