LOSS ISUZU RODEO POWER
16 years 6 months before #7541 by manual-mecanica
Manual-Mecanica Response on the topic Re: Loss Power Isuzu Rodeo
If there is an additional air inlet to which the flow is indicated, if not, this separation that you say your extra air pass?
16 years 6 months before #7547 by manual-mecanica
No, it's just crooked. I also wanted to comment, the car always has contarusions, especially in declines.
Ah, and something else, do you know the ability of the gas tank? The specification that finds says that it is 29gal, however it is filled with 15gal or will it be that the meter was manipulated? Because I have already run it "empty" and the warning light does not turn on nor has it stayed.
16 years 6 months before #7557 by manual-mecanica
It may be that they ayan a bonbo because the original is expensive and when installing it, they did not locate it well and the float is not in the correct position, the counterplosions can be made to the poor condition of the valves, but if they made the engine they had to check and accent the valves, otherwise it is also a rash of power loss since the explosion escapes when the explosion escapes when the escape valve is not Admission but it shows more in the escape, it is also good to check that the spark plug cables have current and deliver a spark Explorations and also lost of ppopity.
16 years 6 months before #7646 by manual-mecanica
Hello, I have already tried the Catalitical and I do not blow. We measure the gas pump pressure, gave 10 lbs.
16 years 6 months before #7653 by manual-mecanica
and the compression of the cylinders?
