Tirones at Renault Clio Chipie 1.2 60cv 1996
16 years 8 months before #7262 by manual-mecanica
Tirones in Renault Clio Chipie 1.2 60cv 1996 published by Manual-Mecanica
Hello I have a Renault Clio Chipie which has come out very good, but some time ago at any speed 20 km/ho 80 km/h sticks very annoying pulls, they notice much more when I go to low speed. I have also noticed that when I turn it on in the morning the engine walks as a clock but when it takes temperature and stops in a very low stop and almost stopping ... I am not very understood in mechanics but if they can help me I would appreciate them.
Greetings
:( : S
14 years 5 months before #21673 by manual-mecanica
Manual-Mecanica Answer on the RE: pulls in Renault Clio Chipie 1.2 60cv 1996
Hello, first try to change the air filter if it is very dirty, that can happen to me, I changed the filter and it is perfect and if it remains the same you have to look at the spark plugs. I hope I have helped you.
14 years 5 months before #21726 by manual-mecanica
Your problma is most likely the fuel pump to check if it has the appropriate PRSION and change the filters may be covered. If that is fine to review injectors and spark plugs)
