Citroen Ax Electrical System Problems
16 years 9 months before #7100 by manual-mecanica
Citroen AX Electrical System Problems Published by Manual-Mecanica
The problem I have is that every time I press the brake pedal I turn on the lugs of low light.
16 years 9 months before #7108 by manual-mecanica
Manual-Mecanica Response on the Re: Problems Electrical System Citroen Ax
Rare really problem.
Czech pedal connections and also the headlights
16 years 9 months before #7130 by manual-mecanica
It is very strange, check the pedal wiring when you go up you are making contact in some bearing.
16 years 9 months before #7135 by manual-mecanica
I agree with Ratmud and Kikemec is a rare problem to begin with some repair before if it is so they did what they did, on the other hand if they have not touched the car because as they say, Cecar lighthouse wiring can be anything like the heat of the engine that costs the protective lining of the wiring and they are left on the bridge, and as the brake pedal such as you see you see the movement of this crushing. You will have to see a visual inspection and comment on us luck : Woohoo:
16 years 9 months before #7137 by manual-mecanica
Check the pilots' brake bulbs. If they are two poles and you have put them in the opposite position, the brake circuit is communicated with the brake circuit with the position and all light up
