Ibiza problem
16 years 8 months before #7069 by manual-mecanica
Ibiza problem posted by Manual-Mecanica
Hello I have a Seat Ibiza 2002 and from a few days here I no longer turn on the light of the board everything else works perfectly only the lighting stop igniting if anyone knows how to be the problem I would appreciate your help very much thank you.
16 years 8 months before #7086 by manual-mecanica
Manual-Mecanica Response on the Re: Problem with Ibiza
Check the fuse box, thas the k handles the dashboard lights is open if so, change it.
16 years 8 months before #7114 by manual-mecanica
tens um Igniçao, troca or canhão de ignição problem
16 years 8 months before #7132 by manual-mecanica
Your lights light with aviert contact?
16 years 8 months before #7133 by manual-mecanica
Most likely if you already checked the fuses is that your problem is the telecoming.
