Stop Partner
16 years 9 months before #7015 by manual-mecanica
Stop Partner published by Manual-Mecanica
Hello people is the first time the forum, since I have a problrma with a partner that clashes, on the board there is a light light that Stop says which does not let me spot it since Nicii wishes heat up, but if it turns the engine. I will appreciate your help thanks
16 years 9 months before #7019 by manual-mecanica
Manual-Mecanica Answer on the Re: Stop Partner
There is a device that is shocked in some cars like Peugeot are in the driver side engine in others such as the Ford are near the side of the companion in this model of you do not remember where it is located only is to press it that you are clicking that a click this device in case of impact is thrown away and there is no gasoline just run
16 years 9 months before #7027 by manual-mecanica
It is the inertial and impact interupator must be in the engine part attached to the brake pump normally take it in that place, if you do not get it, read the owner's manual you will find all the explanation and location.
16 years 9 months before #7047 by manual-mecanica
The same inertial button, Peugeot carries it under the hood, near the right shock absorber, press and arm it again, a boil that there is a fuse of 20 yellow amperes that is cut and that is starting.
16 years 9 months before #7160 by manual-mecanica
I thank you for your concern and response, to my concern, but this truck does not bring the impact switch, I could already start it, since I realized that when we put the gasoil solenode of the Iny pump. He acted. Then I pontie the heating and starting spark plugs, calculation that the problem comes from the preheater, I am looking for it, when I get it, I tell you thank you.
