Honda Odissey. Tracion system problem.
16 years 9 months before #7012 by manual-mecanica
Honda Odissey. Tracion system problem. Posted by manual-mecanica
Good day.
In advance I appreciate your support.
Buy an Odissey in the USA, fortunately cheap, in an auction, unfortunately with failure in the traction system, so I cannot bring it to Mexico.
I turn on, everything perfect, very good functioning, but after a while of running it takes the speed and does not advance anymore, as if it were in neutral, I turn off, I turn on again and again runs well for another time, doing exactly the same thing again.
With my little tool and my coding reader I realize that he has a failure in the traction system and is being deactivated, but unfortunately my team does not give me information beyond telling me that it is failure with the traction, I only suppose and ask God to be a sensor.
I appreciate in advance if someone could guide me, since it is a common failure in these mini van.
Again, thanks for your support.
Misael Galicia
16 years 9 months before #7045 by manual-mecanica
Manual-Mecanica response on the Re: Honda Odissey. Tracion system problem.
Look, I believe that the best thing you can do since you have knowledge of mechanics, is to make an oil change to the box and its filter, since what I understand of automatic boxes that make this fault, for example in Craisler, something happens with the pressure of oil or that is what I told you or something with the precion, it is what I am not an expert in that subject, but you do not lose anything.
16 years 9 months before #7115 by manual-mecanica
I have tried and nothing. Receive my thanks. I hope someone out there has already solved something similar and can help me.
Thanks again. a hug
