Mazda 3 isolated
16 years 8 months before #7011 by manual-mecanica
Mazda 3 isolated published by Manual-Mecanica
I have a Mazda 3 1.6 Triponic Sedan 2008 the car is completely isolated, when I start it, it is mute, everything turns on it and works perfectly, but it does not start, it already replies all the fuses of the engine and those inside and all are good someone can tell me where I look for ????
16 years 8 months before #7022 by manual-mecanica
Manual-Mecanica Response on the Re: Mazda 3 isolated
Maybe because of the starter engine, Czech that arrives current.
16 years 8 months before #7026 by manual-mecanica
Check the wiring possibly some loose connector
16 years 8 months before #7046 by manual-mecanica
Check the boot motorcycle, if the vehicle does not make any noise type when starting with the key, it can only be this problem, if you have a encoded key, you can go through the key, discard the start first, if you do not save like, try pushing the car and make it walk like this.
