on
16 years 10 months before #6933 by manual-mecanica
Light published by Manual-Mecanica
Can anyone explain how the ignition is adjusted in a gasoline car? One of the forms is using a stroscope right?
16 years 10 months before #6958 by manual-mecanica
Manual-Mecanica Response on the Re: Light
A knit pisola, or a strobe lamp, for me it is easier to uncover the distribution and use the marks, another way you can use is to crusate ranking valves in one, suvir piston to the upper dead point and coves it follows it.
16 years 10 months before #6972 by manual-mecanica
The valve cross indicates the PMS of a cylinder, it can be tuned with any cylinder, with the marks it is easy, and with the strobe lamp as it is done?
16 years 10 months before #6973 by manual-mecanica
16 years 10 months before #6985 by manual-mecanica
It depends a little on the system, but in reality the PMS you can put it by hand by turning the crankshaft without a leaf Peugeot, Renault and Citroen, the 1 is the one of the box not of belt.
As for the lamp you can check the point and launch or delay with the distributor's Avans, only in ancient cars.
