pulley noise
16 years 10 months before #6835 by manual-mecanica
pulley noise published by manual-mecanica
That I ask for your opinion about a damage that my car has, which is a Nissan Platina (Clio Symbol, Thalia,) with K4M engine the problem is a noise on the pulleys, this due to an accident that I had, the blow was not frontal if not a lateral pot, that is only one lighthouse, the car was already repaired but from the set of pulleys a metal noise comes out when accelerating; I already check and nothing makes contact with the pulleys that believe it can be the alternator?
Thanks in advance:)
16 years 10 months before #6837 by manual-mecanica
Manual-Mecanica response on the Re: pulley noise
I would recommend seeing the tension of the belt, the tensioner of the same and the alignment of the set. It is caused that if the blow touches any piece, something has been decentralized.
Hugs
16 years 10 months before #6838 by manual-mecanica
Well, I do not have so much experience in this but
the noise in the pulleys is usually given because at the time of the blow some bened If the lubricant of the bealmers finished the noise generated by the bulteria's balines are wearing causing a grinding by the friction of metals, I advise you to check your shots or bearings that the greases and if you need to change them, change them, as if your car needs a new vanda vanda.
It can also be the Tensioner Checala band.
16 years 10 months before #6855 by manual-mecanica
Look first of all, determine where the happy noise is, the easiest thing is the following, take out the straps but one in one, that is, take out the alternator's strap and make the vehicle walk if nothing sounds, check the status of the alternator and of all the components that this strain drags, so you are running by strap, except the distribution if you take it, do not get the vehicle. Sensillo, because I could tell you waters, air conditioning, water pump the Haspas were replaced by the blow, belt tensioner bearing distribution, alternator tensioner and many other things, try to minimize the univerzo of elements in this way and you tell me, so we find the lucky solution
16 years 7 months before #7831 by manual-mecanica
The plain has only a long strap that crosses all the pulleys, mine with a strong rain seems to have saved from a pulley and no if how to put back on each pulley, does anyone help me?
