How to turn off Toyota Hiace 2006 witness
16 years 10 months before #6730 by manual-mecanica
How to turn off Toyota Hiace 2006 witness published by Manual-Mecanica
Thanks in advance I would like help I have problems with a Toyota Hiace Microbus 2006 Turbodiel Motor 2kd distributed here in Guatemala, the Diesel filter witness light stays fixed indicating problem in the elfilter changes the perono filter you are as: Silly: reset
16 years 10 months before #6822 by manual-mecanica
Manual-Mecanica Response on the Re: how to turn off Toyota Hiace 2006 witness
Hello, look I recommended that you feed up a consequence so that with a scanner they review that and reset it to you, it is sure is the ECU, that you have to restart it ...
