AIR CONDITIONED SEAT CORDOBA TDI 1998
16 years 8 months before #6693 by manual-mecanica
AIR CONDITIONING SEAT CORDOBA TDI 1998 Published by Manual-Mecanica
I have a Cordoba TDI of the year 98 and the air conditioning compressor does not work. I have verified the fuses and they are all correct, I have also proven that tension does not reach the compressor group. Let's see if someone has the scheme or can tell me where the failure may be.
16 years 8 months before #6720 by manual-mecanica
Manual-Mecanica Response on the Re: Air conditioning Seat Cordoba TDI 1998
First check if you have gas, then check the prisoner or trini to see if the current comes, after connecting lights the car fan, it can also be the sensor that goes in the evaporator in the internal part of the car, then check the external temperature sensor when it is also damaged, it does not start the compressor, check and let me know
16 years 8 months before #6775 by manual-mecanica
Well, an easy way is to turn on the car connect the A/C if they activate the radiator fans (s) and do not magnetize the compressor is the magneto otherwise if you confirm that it has refrigerant there is a fuse on the battery that when melting or burning not active neither compressor nor fans when connecting the A/C check it lucky: Woohoo:
16 years 8 months before #6785 by manual-mecanica
Thank you very much for your answer. Gas if you have, that sure. But some doubts still assault me. Could you tell me where the prisoner is? I have searched in the engine compartment but I can't find it. And another side, could you also tell me where the temperature probe is placed and if it is a PTC or NTC? If so what are your resistance values.
16 years 8 months before #6786 by manual-mecanica
: Woohoo: The pressure switch goes in the high line of the evaporator to the condenser some have three negative positive lines and the cable in the center handles about three volts to activate compressor and the first of the fans if it brings four cables the Ers prison fans or defect The second of the fans my email is
