Fix engine that has overturned. Possible Gripaje
16 years 10 months before #6607 by manual-mecanica
Good, you will see myself to buy a sinister to use donor. It is a GTI GTI 2.0 16V golf. The car in question overturned and swallowed about 1 liter of oil.
When I went to see him we tried to start it, he did it but he fell at 3 or 4 sec., So they tell me it is possible that having started it had hooked and folded cranks.
In the best case they tell me that spark plugs would have to be removed and giving the contact to expel all the oil from the cameras and I suppose that air filter should be changed and the admission is clean, right? Then I would have to fill with oil so that it has not already done so)
placed in the worst will have folded cranks and I do not know if in this case its repair will be worth it.
Can you have something else due to overturn? Should I look at something else?
Thanks in advance. All the best
16 years 10 months before #6630 by manual-mecanica
First of all, if the car is taken a liter of oil, you have to see where this oil enters the combustion camera, second if it is trancado you must check if it is connecting or follow, the same in the case you will have to invest a lot of money to leave it stable and in good functioning.
16 years 10 months before #6639 by manual-mecanica
Remove the spark plugs and try to turn it by hand before turning with the start and put something down so you do not make an oil lake on the floor when you go to turn it with the start after having made it turn by hand closes the capot because if not the oil will bathe you everything.-
16 years 10 months before #6655 by manual-mecanica
Thank you very much, I will try Aver. They tell me that after doing this I change spark plugs.
