Haogadas spark plugs
16 years 10 months before #6579 by manual-mecanica
Haogadas spark plugs published by Manual-Mecanica
Hi, I have a 2003 tsuru 16 valves and my problem is where the spark plugs accumulates oil from the outside I do not know how it happens if anyone knows how Areglo this would appreciate it
16 years 10 months before #6588 by manual-mecanica
Manual-Mecanica response on the Re: Haogadas spark plugs
Generally the spark plugs are near the valve lid, when the joint is spent, empies to lose a thread of oil, this generates that you have oil outside the engine, start by adjusting it, with care not to pass with the adjustment! You can cut the joint, and try it, if you continue to throw oil you will have to change the joint, it is not expensive, in
Argentina
16 years 10 months before #6593 by manual-mecanica
If the oil is outside the spark plugs and not at its tip where it gives the spark, the problem is not engine, if not oil leaks due Packaging is in good condition you put the same but, you change it, and voila, the packaging burns with heat and for the passage of time, it is nothing serious but everything is dirty and the engine is horrible.
16 years 10 months before #6645 by manual-mecanica
Good evening pleasure in the forum, the packaging of the lid of the valbulas is bad when changing it peg it with silicone
16 years 10 months before #6646 by manual-mecanica
