Bencina expenditure
16 years 10 months before #6449 by manual-mecanica
Bencina Expenditure published by Manual-Mecanica
I have a 92 'Motor 1600 Luv, and at this time he is yielding as 6km per liter ... and at the time of occupying it ... it is an intense smell of benzina through the exhaust tube ... who could tell me why this happens .. ??, ... thanks ...
16 years 10 months before #6485 by manual-mecanica
Manual-Mecanica Response on the Re: Bencina Expenditure
Well, because of the smell in the exhaust tube, apparently the fuel is not consuming at all, perhaps it is a ignition problem, the spark plugs, the cables
a question is carburada?
16 years 10 months before #6490 by manual-mecanica
The spark plug cables are new ... but the spark plugs carbonizes them, I have to be cleaning or changing almost every week ... if you have carburetor ...
16 years 10 months before #6497 by manual-mecanica
If the machine is carburad, this past recontra of gasoline in the regulation, you will have to see, automatic advance of the distributor, air needle and others, it needs a carburement and urgent tuning
16 years 10 months before #6507 by manual-mecanica
The first thing you have to perform is a cleaning and maintenance of the carburetor, before the abass or anything else, it is important Packaging gum pack and everything, eye that carburecion you have to do it with a gas machine, that is the correct shape, if you do not want the eyes are good indicators if they bite it is very high, you give the screw until you like it, but the best thing is with a machine.
