Lancia Y-10 Fire
16 years 10 months before #6347 by manual-mecanica
Lancia Y-10 Fire published by Manual-Mecanica
I have 1 the Y-10 Fire, and I flooded me with oil 1 of the cylinders and loses almost all the power, how can I solve it?
16 years 10 months before #6368 by manual-mecanica
Manual-Mecanica Response on the Re: Lancia Y-10 Fire
You will have to lift the cylinder head and look at what has been broken.
It can be a breakage of piston segments, or rupture of valve seals in butt.
In the checkbook, the camshaft can be removed with the cylinder head and with the help of a useful, release the valves of its semiconos and casserors to change the unopened cooking seals, but ...
1º is fucked
2nd 2nd you need to have experience so as not to shit it (it is very easy to shit it)
3º You run the risk that this is not the breakdown and in the end I have Cylinder wear, it is not going to have a step of the ostia and have to rectify or change motor for wear.
All the best.
16 years 10 months before #6397 by manual-mecanica
100% according to megabeat_1, uncover the cylinder head and see the safe one is clear where the oil is passed a veal, the most likely or the most common are the vessels of valves or guidelines of valves but sees the safe and uncovers.
