Ibiza brakes
16 years 10 months before #6288 by manual-mecanica
Ibiza brakes published by Manual-Mecanica
Good, the other day I started to scream my front brakes of my Ibiza and notice and had no pills, I bought the pills in a spare parts store and I started to mount them, but I was not able to be able to kitar the clamp to kitar the old pills and put the new ones, if anyone could explain how it changed it I would appreciate it. thank you
16 years 10 months before #6298 by manual-mecanica
Manual-Mecanica Response on the Re: Ibiza Brakes
The change of pills is simple, I do not know your model because I have never had to change them, but himajino that is the same as everyone, you take the wheel loose the bolt below the caliper and move you have a lot, if you do not move the rod one too and take it out, if you are hard you hit it a little so that you release, now you have to look Caliper and access the pills.
