SJ413 motor problems
16 years 11 months before #6273 by manual-mecanica
SJ413 motor problems posted by Manual-Mecanica
Hello friends soi new aki and I would like to know if you can help me since I have problems with my mptor does not work a piston and get a spark plug with conbustible that you think you can be oq devious to please help me in this problem.
16 years 11 months before #6283 by manual-mecanica
Manual-Mecanica Response on the Re: Motor problems SJ413
The spark plug is getting wet because there is no ignition, so the piston does not work. The problem apparently is Czech electric part of the distributor, the cable that conducts the spark. And Czech is p. To know your engine a little more, it is in English but it has images so with a translator the pounds.B) luck. www.4x4.in.th/manual_sj413/index.html
16 years 10 months before #6296 by manual-mecanica
Verify that this cable has current if you do not have it, the spark plug is bad if you do not check the cable that is not cut, the distributor if the estate of Est has, it is not complicated will you arrive soon to the failure, it is with that with that the engine SJ 413 is from a Suzuky right?
16 years 10 months before #6313 by manual-mecanica
It would not be more than compression, it would not be that you would have gone any valve and the cylinder has not left without compression.
Sometimes it happens, it is a whore, but it happens.
First to the easy, you take out spark plug, put it to dough, turn to start and if there is cramp ... it is not spark plug ...
and if it is not spark plug ... Chungo.
I hope this is not your case and that it is an easy breakdown.
