Remove r19 start motor
16 years 11 months before #6194 by manual-mecanica
Remove R19 start motor published by Manual-Mecanica
Hello, I need to tell me how I take the boot engine of the Renault 19 RT 1.7 F2N engine. I lowered the manuals, but I can't open it. Thank you so much. My email is
16 years 11 months before #6243 by manual-mecanica
Manual-Mecanica Response on the Re: Remove Motor Start R19
The first thing is to mouth the battery to avoid problems. Then in the F engines you have to remove the engine air filter.
Once this is done, you can access the starter engine to disconnect the battery positive cables and the terminal that comes from the contact key.
With loose cables, the three screws that hold the start to the gearbox envelope are loosen.
The starter motor comes out of the right wheel, behind the wheel.
All the best.
