Ford position 1722e
16 years 5 months before #6144 by manual-mecanica
Ford position 1722e published by Manual-Mecanica
Hello, I am from a very isolated area of ​​Chile and I have problems with my Ford position 1722e. The truck does not part and the witness light of the preheater of the engine does not turn on the internal diagnosis of the truck does not work. I would like someone to guide me.
16 years 5 months before #6162 by manual-mecanica
Manual-Mecanica Response on the Re: Ford position 1722e
Hello, look for oil trucks, the reasons are not very complicated, but I need to save if before you failed it was working properly, to eat two things, that the incondent spark plugs hot and that it arrives oil, if you have these two things you warn me if any do you miss to be able to deduce where to go, cook the battery and its load.
15 years 8 months before #9962 by manual-mecanica
Hello, does anyone have the Ford position? I want to save how the brake system works thanks ... :(
8 years 1 month before #52260 by manual-mecanica
In the fuse box there is a green fuse of 30 AMP this feeds the motor control module if it is okay to check the control module connector is the largest. Batrria must be disconnected to take it out then check inside the harness in case there are cut cabled. It has to take it to the base of the cabin and disassemble it check line by line. I happened to me in several 1722. And they had one or two cut lines or the alternator's feeding cable I work with Ford position I hope this information serves
8 years 3 weeks before #52305 by manual-mecanica
If the food fuse burns disconnects the ECU and the ECU is no longer burned, you must replace it greetings
