Velocimetro Ford Focus 99
16 years 11 months before #6082 by manual-mecanica
Velocimetro Ford Focus 99 published by Manual-Mecanica
First of all, thank you contributions and I hope to be well received in the forum. I have a 99 focus and runs out of velocimetro when he wants. After rolling for a while some stripes come out on the marker of partial and total km. I have located the speed sensor in the Camb iOS box, but I don't know how to get it out. Thanks in advance, Juan Carlos
16 years 11 months before #6096 by manual-mecanica
Manual-Mecanica Response on the Re: Velocimetro Ford Focus 99
Generally, the velocimetro is screwed with a Turk a point crown will serve you, in general they are 17, 19, 21 mm measured, but generally these when they fail they do not mark it is not that they mark melting, so you want the problem not this is not in the score Solve the problem, the Scaner will only tell you failure in the speed sensor if it does not do so is the indicator itself.
