Hello someone can guide me. I have a 2005 micra
16 years 11 months before #6026 by manual-mecanica
The address does not work, it is hard as if it were standard
16 years 11 months before #6032 by manual-mecanica
Give us a little more information, a little more detailed. Czech the level of the liquid, maybe there is a leak or is under the level.
16 years 11 months before #6036 by manual-mecanica
The micra has an electrohydraulic assisted direction, that is, it does not carry hydraulic pump dragged by the motor of the car, but it carries a hydraulic electric pump that provides the necessary pressure for assistance.
This electric pump is connected and disconnected when you turn the steering wheel, through motion captors and an electronic module that governs the system.
What you can do is refer to the car use manual and see which is the fuse in the box to see if it is molten, also look at the manual in the \ "levels \" or \ "lubricants and capabilities \" or something like that, where they will come in detail where the caps are to replenish the brake fluid, the antifreeze, the water of the clean, the engine It is more than anything, because as fellow ratmud says, it is possible that the oil is out of a leak and the tank is empty.
If everything you can touch is fine, and the problem persists, prepare the portfolio and take it to the workshop because the breakdown can be \ "fine \".
All the best.
16 years 11 months before #6068 by manual-mecanica
Also check how much the alternator charges since if it is under the voltage northly I came deactivated the direction assisted directly from the car switch
16 years 11 months before #6077 by manual-mecanica
Because of the address problem of my micra, take it to the Nissan workshop and tell me that you have to change the address system, and it is very expensive. I think that other cars have broken down a PS signal and the address is set on the board and the direction becomes rigidly and was the air conditioning stopped working
