Problems with Suzuki Samurai SJ 413
16 years 11 months before #6013 by manual-mecanica
Problems with Suzuki Samurai SJ 413 Published by Manual-Mecanica
Friends for some fact to be able to get the following corduroy: when it is cold and it is given a start after heating is accelerated and restless
16 years 11 months before #6047 by manual-mecanica
Manual-Mecanica Answer on the Re: Problems with Suzuki Samurai SJ 413
SJ 413 is carburation.
You should check the state of the carburetor, if the Cuba overflows, if the air chiclés (economizers who are responsible for impoverishing the mixture as you accelerate) are clean or if on the contrary they have the flutes full of dirt, the status of the starter, which sometimes remains stuck and a half closed ... in fine, disassemble the carburetor of the car, clean it with a solvent, a brush Patience, modal a new together kit and put it again, you will see how the matter changes.
All the best.
16 years 11 months before #6057 by manual-mecanica
Quetal thanks for the answer .... But this jeep has a mono point injection, so they do not have gum or
targe
16 years 11 months before #6063 by manual-mecanica
Check an air aspiration or fuel pressure
16 years 11 months before #6090 by manual-mecanica
Generally, the problems that have an unstable relaying failure are usually improved or results when you clean the Relay or IAAC valve, these valves are filled with dirts and they should clean them before changing them to rule With a malfunction of the TPS or even you want only the temperature sensor, but it is better to scan in the long run it is more varato and less cumbersome, but if you specify the fault we can guide you, to what number of rpm failure in which marches you go, what speed rates how much it takes to start and other useful data
