Does not turn on my astra
16 years 11 months before #5966 by manual-mecanica
Do not turn on my astra published by Manual-Mecanica
Buy a 2005 2.0 Astra with 68000km I have traveled with 500km and until yesterday everything was going well without a sign that something was wrong, however today they did not leave only the foci of the board are turned on by giving but this is not generated. Can anyone help me or guide what is due?
16 years 11 months before #5971 by manual-mecanica
Manual-Mecanica Answer on the Retra
Check the terminals of the battery or battery may be that an element of it has been damaged.
16 years 11 months before #5977 by manual-mecanica
You should give us a little more information, your vehicle makes some noise or just starts click, the pump relay sounds, tends to start but does not, you have to tell us something else, see in the first place the clip of the battery terminals, it can be the starter engine if nothing turns you, or that your battery is dry, how long do you have it? Water or is free of maintenance, see if your alternator loads or is broken, if you do not save how to tell me and explain an easy way to do it.
16 years 11 months before #5981 by manual-mecanica
A little more detail, right?: HUH: The most common if you do not even listen to the march is k it is a failure of the Czech battery if it is making good contact and the terminals are not sulfate, if so disconnect them, clean them and connect them again and try to turn it on.
