Isuzu Rodeo Manual 93
16 years 10 months before #5893 by manual-mecanica
Isuzu Rodeo 93 manual published by Manual-Mecanica
I already have the manual that is on this site has served me but Alahora to install the heads The same model I want to ask you if any of you has the manual of model 93 and I could let me arrive, I would appreciate my email silverfox_450arrobahotmail.com :)
16 years 10 months before #5895 by manual-mecanica
Manual-Mecanica Response on the Re: Isuzu Rodeo Manual 93
Specifies a little more that I have lost ...
when it comes to riding the heads? What do you call heads? If you explain it to me a little more, maybe I can give you a hand around right here.
All the best.
16 years 10 months before #5958 by manual-mecanica
Hello, I refer to the valve body that is the superior immediate part of the pistons, squeeze them at 9lb I have the camshaft, now I do not remember the front as disarmed, because I do not know how the pulleys and the hoppers go.
16 years 10 months before #5962 by manual-mecanica
That is, you have a problem with the tightening torque of the butt screws, (Torque of Cilinder Head Bolts), and with the distribution draft (time strap) (Timming Belt).
I need you to tell me the type of engine that carries the rodeo, so that a scheme of the assembly and draft of the distribution passes you.
I also need your email because the file weighs a lot and if I post it here the image comes out very small and it almost does not see.
All the best.
16 years 10 months before #5967 by manual-mecanica
Hello, look at the engine is v6 3.2 l. And my email is And I would be very grateful for the information asta soon.
