VW path 94 1.6 Audi smokes oil
16 years 10 months before #5885 by manual-mecanica
VW path 94 1.6 Audi smokes oil posted by manual-mecanica
How, I have a problem with this car, I smoke oil, we did the full cylinder lid, the motor set does not have remarkable wear as for this smoke, it does not have the staggered cylinders and do not hit the metals, the escape is full of oil previously burned, but does not come through the size or by the gas recovery.
16 years 10 months before #5898 by manual-mecanica
Manual-Mecanica Answer on the Re: VW path 94 1.6 Audi smokes oil
Defective valve or seals guidelines, oil sneaks from above through the valve offspring and falls inside the compression chambers. Fill everything with carbonilla and admission collecting stain inside. But I don't blow for the vent !! With which you go crazy until you give the failure.
Anyway, these seals are changed when you are cooked to avoid this problem, just as the cylinder head is planned, it is checked under if there are cracks, the slack of the valves of the valves inside the guides is checked ... in the end, rectifying works when you have to lift a cylinder head, the same as if you disassembled pistons, it is normal to put a game of segments (piston rings) connecting rod and bench, which does not represent a very large expense but can cause you a very fat problem.
All the best.
16 years 10 months before #5909 by manual-mecanica
Thanks for the prompt response, but the cylinders lid is thoroughly, guides, snows and flat, but still smoked !!
16 years 10 months before #5913 by manual-mecanica
You have done the cylinder block, you wear if the pistons have axial game, this also produces the humo I would do that engine, to saver where to go, greetings
16 years 10 months before #5914 by manual-mecanica
