Hyundai Galloper 99 V6 Automatic
16 years 11 months before - 16 years 11 months before #5874 by manual-mecanica
Hyundai Galloper 99 V6 Automatic Published by Manual-Mecanica
: S Hello, I have a galloperii truck year 99 Automatic the problem you have? That the position of the position of the change lever is fixed in \ "d \" or what is the same does not matter if it is in p; r; n; d; 2; or l is only on in \ "d \". Someone can help me with this technical problem. Thanks beforehand
Last edition: 16 years 11 months before by .
16 years 11 months before #5899 by manual-mecanica
Manual-Mecanica response on the Re: Hyundai Galloper 99 V6 automatic
And if you put the lever in n the van tends to walk alone when you release the brake as when you have the march on?
If you walk alone even if you put it in N, you have the problem in the box, which has been locked with the march on.
If the van behaves normal, all the marches work, in n it does not come out and yet the light does not go out, it means that what happened to you is that either the captor of the lever position was broken or that the cable that lights the witness is making a mass and is turning the witness irregularly.
Normally, if you are not in p or in n should the commissioning of the engine work do not? It would be interesting that you tell me if it starts normally or if on the contrary you cannot start it.
All the best.
16 years 11 months before #5900 by manual-mecanica
B) Thanks friend for your information. The box works perfect. I think what you inform me about the Light captor box of the lever position, on turning on the vehicle and putting any position the change lever perfectly enter the changes but no! Change the position light. Therefore I attach to the possibility of that contact box unfortunately in the manual that downloads in this way does not indicate me precisely where said contact box is located. I imagine it is part of the gearbox. Thank you again for your support and I will scrutinize the vehicle to see if I get it.
Greetings from Venezuela.
16 years 11 months before #5911 by manual-mecanica
Hi Mahalo2003, as Megababat_1 says if the vehicle works normally, you have no problem in the box, but rather in the gear indicator, look in Craisler's models for example caravan, when disassembling the instrument panel you immediate Unique non -resistant is the plastic where this spring hooks that breaks easily, it can be there that you have the problem check it anyway you do not lose anything,
16 years 11 months before #5919 by manual-mecanica
Thanks Kikemec I will do
