Wet oil spark plugs in tsuru gsii 95
16 years 11 months before #5818 by manual-mecanica
Wet Oil Spark plugs in Tsuru GSII 95 Published by Manual-Mecanica
Hello please helpmne, I have a tsuru gsii 95, engine 1.6 16 valves and a spark plug gets wet with oil but not the electrode but the camera where the spark plug enters then I have problems because the current fails me since for this reason the spark plug cable does not make it well and the car is thrown, I have no idea that it can be or because that happened! Hopefully someone can indicate what happens
thanks: Huh:
16 years 11 months before #5819 by manual-mecanica
Manual-Mecanica Response on the Re: Wet Oil Spark plugs in Tsuru GSII 95
Explain a little better if it is on the internal part is one thing if it is outside it is another, if it is outside what I think can be the enhance of the alvules that loses oil, if it is by the internal they can be several things from a guide of valules to a game, everything depends on the defect .-
16 years 11 months before #5826 by manual-mecanica
It is not internal since the electrode is dry, what is wet is the ceramic part, where the distributor cables are connected to the spark plug, I do not know if there is any packaging inside the aterpiece that does not allow the oil between the spark plugs
16 years 11 months before #5844 by manual-mecanica
Good evening, see if what you are put from oil is the cable, I imagine that your spark plug cable Packaging of the valve lid, it is with the shape and inside it brings the rings and that is all nothing more, it seals with a little cylicone to save 100% that will not filter.
16 years 11 months before #5891 by manual-mecanica
I support Kikemec's response, on the Peugeot line, there was a 504 model that has a similar system !!! Change the packaging and the upper seals (rings) and when the refusals put a joint lightning on the cylinder lid, put the packaging and on this put again cells together, then mounted the lid and tighten it, and inside a few days stick a readjustment to the lid, if not the readjustment can lose you again !!
Good luck, and warn what happened!
