Help Froge Vito110D Year 96
16 years 11 months before #5743 by manual-mecanica
Help Froge Vito110D Year 96 published by Manual-Mecanica
WNAS I am an inexperienced Mekaniko for lack of experience and I went out of the school in June of finishing my studies and I am in agricultural machinery I pass the cars I also like and I approach my buffs tooa if they can help me this is my pekeñito problem:
Algen knows how the clutch of the van Mercedes Vito 110d is disassembled. K is indicating the automobile technique magazine but says K Ay k disassemble the axis, let's say from the transmission k goes from the differential to the stick and I can not disassemble it, the axis passes through a support that I think is also the support of the alternator this axis in this area has as a cisne neck we say that it would have to leave the wheel. I said axis and that is why I do not get or oh, extract with extractors or nose if it is kept or kew Throwing acia outside this axey k has been afraid and I closed the housing again and I think it should be disassemble The garage very thank you and a cordial greeting of Ruben
16 years 11 months before #5745 by manual-mecanica
Manual-Mecanica Response on the Re: Help Froge Vito110D Year 96
At the moment the change does not come out because it carries clutch and collar embedded in maza, that is, it does not click but it throws, it has to have a pin to be able to remove the fork, then the stick can be put only stuns of the box and this is already
16 years 11 months before #5747 by manual-mecanica
That pin where the axis is already located in the differential and `passes from the side of the van ai a pin the right is the right the support or piece k holds the transmission flange of the transmission of the transmission dde the zech shore the zeq and the time it is the support of the length you will refer to that pin
Once this axis of the aprotive differential a little in the motorcycle steering wheel is and I separate the entire box of the engine and I already have the clutch wing ????
The orkilla k tells me that pin where it is located or does not have any dixa orkilla
mxisimas thanks a cordasl greeting from Ruben
