Radio problem
17 years 1 day before #5687 by manual-mecanica
Radio problem published by Manual-Mecanica
I have a music and music team that consists of a stage 2 media and a subwoofer all blaupunk, well the team only put the Saturday for the bottle and then I always walk by removing it and putting it but yesterday gave me pr put it and I do not do well and the problem is that because of the speakers of the car when the stage that is when the equipment is operated, because I put the intermittent for example if I put the intermittent ones. The intermittent and if you do the command of the lights the same sounds as interference, well my question is that if that is of the radio or the power stage because the INTALACION is reviewed 100 percent
17 years 20 hours before #5691 by manual-mecanica
Manual-Mecanica response on the Re: Radio problem
Hi Minabo, the truth is that such problems is only installation and not of the team, independent of how many bojes, amplifiers, subbufers, basucas and how much you want to put it, but the problem passes because the team is amplifying all the waves that reach it. Now you can change it by Pocition and Deveria pass, or isolate it a bit, they also sell devices that avoid these incombenants, but it is not the equipment if not the installation.
17 years 19 hours before #5692 by manual-mecanica
Hello, I think you have a parasitic problem. With an antiparasitic filter you should solve it or so I have understood because I am not very much on the subject.
17 years old, 12 hours earlier #5697 by manual-mecanica
Kikemec The installation is well reviewed but it is all right, something has been putting the leg, I will review it again.
Colt Boi to look for an antiparasitos i boi to try if it is hai too.
Thank you very much for the two for the help I will be aware and I will tell you what you have, thank you very much.
16 years 11 months before #5730 by manual-mecanica
The problem is in the installation, noise is being put to signal K reaches the amplifiers (stages) to the equipment cable of the equipment must be receiving the frequencies of a main voltage cable of the light controls of the car check the installation.:)
