RPM sensor Peugeot Boxer 2.5 TD
17 years 1 week before #5527 by manual-mecanica
RPM Peugeot Boxer 2.5 TD sensor published by Manual-Mecanica
Hello everyone, someone can define how to get the information from the RPM from the engine from the captor located in the speed box.
It has 3 cables, identified in the tab as 1 2 and 3,
I need to connect a cruise speed control and so that it is activated, it must have a rpm signal.
It would seem that this captor only serves to measure the RPM, since when the engine has unplugged it has not had problems of marching and/or starting.
Thank you so much.
16 years 10 months before #6523 by manual-mecanica
Manual-Mecanica Answer on the Re: RPM Peugeot Boxer 2.5 TD Sensor
1 12 V
2 feeding Signer
3 MASS MASS
The signal signal is sinusoidal and occurs between 2 and 3 as a small voltage variation.
Between 1 and 3 there are 12v with positive contact to feed a primary coil that generates the magnetic field of the sensor.
All the best.
