Change the Ibiza's rear brake pills, 98
16 years 11 months before #5504 by manual-mecanica
Change the Ibiza's rear brake pills, 98 published by Manual-Mecanica
I have had a problem when trying to change the rear brake pads of my Ibiza, 98, when trying to go back the piston to place the pills, there has been no way to do it, is it possible that he goes to thread?
Thank you very much, what tool I need in case it is? Thanks again
16 years 10 months before #5505 by manual-mecanica
Manual-Mecanica response on the Re: change the back brake pads of the Ibiza, 98
Hi John, they sell a kit for this but well, see if the piston has to put an Allen key in the center of the head if it is so turns the piston and pushes at the same time, there of a screwdriver or what you see, but between the pill and the album puts a large screwdriver and leverage, goes slow and is hard, a greeting a greeting
16 years 10 months before #5508 by manual-mecanica
Hello, the truth is that in the center of the piston, I have not observed any entry for any Allen key, try to be a screwdriver and ... To throw it back, I really do not know what to do, remove the plon of the \ "bottle \" of the brake fluid so that the level could rise a little, and yet nothing does not, I do not know ...
16 years 10 months before #5514 by manual-mecanica
Try loosening the clog and Apanlanca then, you can have the clogged hose
16 years 10 months before #5522 by manual-mecanica
Hi, Joohn, looks at the best way to saver is to look at the cylinder, if that conception of the common cylinders that goes inwards, it is only aggravated pere, if it is Pplano and it has a kind of cross then it is curled, as the masda 323 possesses and other models or as the sub -arch Loyale Corona how vasting large, if the cylinder is normal, just have it eased with a bank or with what you have on hand, I to stop fighting with the caliper bought a press C, which is what the carpenters use to affirm the wood to the tables, here in Chile it cost me 2500 Chilean pesos around 4 dollars saves a lot and Nienes to make strength or break your fingers, try nothing.
