Ford party 1.4tdci atmosphere
16 years 7 months before #5575 by manual-mecanica
Manual-Mecanica response on the Re: Ford Fiesta 1.4Tdci Environment
You turn on check light in the dashboard so you explain that some open injector is left and lose the pressure of the circuit to how much revolutions makes you the defect since speed can also be the low pressure pump that causes you problems.
16 years 7 months before #5623 by manual-mecanica
Hello short circuit,
the typical orange light of the motor symbol is lit, that which is so generic. According to the workshop, all the injectors, the pump and the motor management stage (the electronics) have changed, but it kept giving them the failure? The diagnostic computer did not indicate anything and that's why they say they lined themselves to disassemble engine. As for revolutions, it has always happened to me about 100-120km hour, on the highway, that is, to normal revolutions, about 3000
16 years 3 months before #7670 by manual-mecanica
Look, 18,000 km passes is complicitly false that happens to him for that. I have spent 20,000 and the car is like new. Don't get milongas. I have the Misto Car. And I think it can be the injection pump, but I am not sure. But what is certain is that they lie to you when they tell you about going the km.
16 years 3 months before #7679 by manual-mecanica
Look at me, something similar happened to me, the vehicle stopped after a while of walking and when I stopped he only took the key and gave him a black start and then passed again, I took out the thermostat and improved, now if you have camon rail you must check the lift pump.
15 years 1 day before #14746 by manual-mecanica
Hello how are you? What I tell you does not know if it will serve as a comfort or will help you.
I have the same car as you, a 1.4 tdci party. Returning from the field I began to make this erro that you say. It stops, as it runs out of fuel, and after walking, but reaching a certain speed stays.
At the beginning I did it when I reached the 80s, then I passed me at 40, other times at 90.
I change the radiator, change the fuel filter, change the high pump, change the battery and the problem continues to insist.
What I recommend, which I am doing now (4 months ago that I have the car in this situation) is to lift the 2 wheels onwards and make it walk to a scanner. Because the error does when the car is walking, but it will not mark the computer.
At this time the car is scanning me and a failure in the left brake information appears, which may be sending bad information to the car's computer and that is why it does not let me go to more than a certain speed.
What I recommend is that you do the same to see that it marks you. It is undoubtedly an electrical problem. Some sensor is sending bad information, and this may be due to an overheating of the car that some cable inside the engine may have burned.
I tell you that the same thing happened to me, I just had made the oil change and returning from the field with the garbage covered radiator, the car presylted and began to fail. The big problem of this is that it is not known where it is failing until you escape while the car is walking.
I hope you are lucky and hope to fix the two cars because it is a shame.
Any novelty I keep you aware.
a hug
